Arris G18 stuck in a reboot loop
  • July 1, 2025
  • 127 views
After discovering that the modem was rebooting every 5 or 7 minutes “exactly” I completed a “Restore WIFI Defaults” action this cleared this rebooting looping condition. Apparently the restore allows the firmware to reload clean defaults fixing erratic behavior like I was experiencing. My question is how can I determine what the actual cause that sent the modem into this condition in the first place? The modem is relatively new and operated great for a couple weeks before this problem occurred. I don’t want to have to do a restore everytime this happens going forward. Any suggestion would be appreciated.
The G18 bootup process takes longer than other SURFboard gateways.  After successful activating, a firmware update is pushed from our server to the G18 which will result in multiple reboots.  The LED is Amber when the unit is rebooting.
Could you please let us know the name of your internet service provider and the speed plan which you subscribed from them?
When your gateway starts rebooting on its own, it could be due to poor signal reception or power fluctuations. To address this, try plugging the gateway into a different outlet. Additionally, to rule out service-related issues, check the cable signal levels.
http://arris.force.com/consumers/articles/knowledge/G18-G20-Cable-Signal-Levels
My ISP is Comcast. Speed plan is 400Mbps.
All signal levels are with specs. Power source is reliable.
While investigating the rebooting issue I watched the Modem reboot no less than 10 - 12 times.  It wasn’t until I performed the “Restore WIFI Defaults” action that the Modem began functioning normally.  It worked normally for about a week until one morning the Download speed was at 1.33 and upload  at 1.10  I powered the Modem off/on and it returned to normal and has been working normally for a couple days now. I don’t know what’s going om with it. Please advise. Thank you.
