connectivity issue
  • August 28, 2025
  • 57 views
I installed an Arris G-20. After about a week it started cycling through reboots to connect.  It won’t stay connected.  Xfinity says the device is faulty.
Could you please let us know who your internet service provider is and the speed plan you have subscribed to?
Does the slow speed occur only on the Wi-Fi, or does it also affect the wired connection as well?
If the issue occurs on both Wi-Fi and wired connections, we recommend checking the cable signal levels within the gateway. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
When the signal levels are within the recommended range, your gateway can maintain a stable, high-quality connection to the internet
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G18-G20-Cable-Signal-Levels
The cable signal levels displayed on the interface page reflect the signals being transmitted by your Internet Service Provider (ISP).
If you notice that these signal levels are outside the recommended range, we suggest contacting your ISP to have them reviewed and adjusted accordingly.
While ISPs may have their own approved signal ranges, for this gateway to function properly, the signal levels must align with the acceptable values outlined in the reference article provided.
