G18 says no wifi connection
  • January 18, 2025
  • 244 views
Called my provider they activated device on my network I go through the steps all the way to the end tells me I’m good I can connect to the modem but it is not providing connection even though my provider said it is receiving connection not really sure what else to do
  • January 18, 2025
try a factory reset and reinstall? Might be worth a shot.
Do wired devices work?
Could you please help us understand the LED light status on the gateway (G18)? Also, may I know who your internet service provider is and the speed plan you have subscribed to?
  • February 17, 2025
My provider was here yesterday and WIFI is still intermittent.  Too late to return so now I have an expensive paperweight and new Modem and separate router.
Could you let us know the product model number to assist you further?
