G18 slow speed
  • August 11, 2025
  • 73 views
I am having this issue too and looking for a solution.
Could you please help us with your product’s model number?
  • August 11, 2025
Mine is a G18.   With Ethernet, I get 90 mbs when I should be receiving 300 mbs.
  • August 11, 2025
It also frequently needs to be restarted or there is no internet despite a blue light.
Are the internet drops and the speed drops happening only over Wi-Fi as well?
If the issue occurs on both Wi-Fi and wired connections, we recommend checking the cable signal levels within the gateway. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G18-G20-Cable-Signal-Levels
The cable signal levels displayed on the interface page reflect the signals being transmitted by your Internet Service Provider (ISP).
If you notice that these signal levels are outside the recommended range, we suggest contacting your ISP to have them reviewed and adjusted accordingly.
While ISPs may have their own approved signal ranges, for this gateway to function properly, the signal levels must align with the acceptable values outlined in the reference article provided.
