G20: Issues with Location Services on betting sites
  • November 30, 2025
  • 15 views
I installed a brand new G20.  Since then I've been having issues with location services on betting sites but only on my desktop.  Rebooting the gateway fixes the issues for a little bit of time but eventually the issue returns.  Its happens on multiple sites.  Sites like Google Maps are unaffected.  FYI I am not using the onboard WiFi radios - they are disabled - because the modem is in my basement and I have other APs that broadcast an existing WiFi network that I have been using for a long time.
Could you please confirm which device is experiencing the location service error? Does this issue occur on just one device or across all devices?
If it happens on a single device, could you also confirm how that device is connected—through the access points or via the G20 using Ethernet (since the Wi-Fi radios are disabled)?
