G20 says device is not capatible with Cox
  • February 1, 2025
  • 53 views
I have tried to change to the device and Cox flags it as not supported. When I have them do it by phone it will not connect to the internet.
As ​@plemans mentioned the G20 is compatible with COX communications and please refer to the link below, where you can find the compatibility list for COX communications
http://arris.force.com/consumers/articles/General_FAQs/Service-Provider-Modem-Compatibility-List
  • 2298 replies
  • February 2, 2025
they literally have a support page for it on their site.
https://www.cox.com/residential/support/arris--surfboard-g20.html
Maybe try a different rep at cox as the one you were talking to probably didn’t have a clue.
