Older extender compatible with G20
  • November 24, 2024
  • 19 views
I have a Linksys extender RE7000 purchased about 4 years ago,  but not able to connect.  Is it compatible with G20 ?
It should connect fine. make sure the g20’s wifi is set on wpa2/wpa3 mode and not just wpa3.
I’d also check on the linksys forum for alternative ways to add an extender
  • November 25, 2024
