We recently bought a g34 , set it up and it all works great but when we try to add an outdoor wifi outlet the app sees it but it times out. We have successfully added this outlet to another router and it works great we have concluded after trying every which way and getting the same result it may be the router settings-any help is appreciated. The plug is made by Tessan and has 3 outlets so you can plug something in and turn it on and off remotely thru wifi.
Best answer by NHBoomers
