My original G34 was losing wifi and hardwire connection daily. I think constantly having to reset caused the button to go bad. I just got a replacement router this week. Now I’m back in the same situation of losing wifi and connection. Before I do a reset sometimes the administrator console will never connect. Before the reset I often have to wait 10 - 20 minutes for it to respond until I reset which will speed things up, but only for a few hours. I only have a couple of wifi devices. Almost everything is network wired. My provider is Spectrum. I’m beginning to suspect there is an incompatibility with the router. Our jobs rely on a reliable router. This router is acting just like the first one. I’m digging into the logs now. there are a few IP6 critical errors. I was going to get support involved but I can’t have the interference during the day. Any first suggestions? BTW, G34 is a Spectrum compatible router.
Before this I had a TPLink router that worked flawlessly but it was 300M router and I needed another router for 1G.
I found a link that describes the same issue I’m having.
