I have a G34 that for some unknown reason is having a problem with 2.4 Ghz band. I ran a speed test yesterday and my download speed is is 5 Mbps ! My 5 Ghz speeds are over 400 Mbps. I have tried different channels to no avail. Speed remains the same. Router is 1 month old and is on Comcast. A This problem started 2 days ago. Any ideas on what happened?
Answer
2.4 ghz wifi very slow. Was fast
Hello DrCorvette,
As you had mentioned that you are facing issues on connecting the 2.4GHz and also tried different WiFi channels .
Try following the below link
Let us know if this helps .
