I just got the G36 wifi modem and am trying to connect everything. My laptop used to recognize the 5 GHz wifi but every time I open up my laptop I have to reconnect and it no longer shows this option so not sure what to do! My printer only recognizes the 2.4 GHz or guest but does that mean anything on the 5GHz can’t print from this air printer? I’m sorry if these are dumb questions but my phone and tablet no longer find the printer and they are on the 5 GHz! Appreciate any info! This has been quite frustrating!
5Ghz not connecting on air printer - G36.
On the laptop are you facing this issue only on 5G network or even with 2.4?
Changing the Wi-Fi channels will connect to the respective networks (2.4 and 5Ghz)
Printers are compatible only with 2.4 network alone so that should be connected to 2.4 network. But during the initial setup the printer and the client device should be connected to 2.4G network then you can switch it to 5G.
