Authentication Certificate - G34 Wi-Fi Cable Modem
  • January 15, 2025
  • 72 views
Does AARIS now have a valid authentication certificate for G34 Wi-Fi Cable Modem? How safe is it to use the 192.168.0.1 address? Can my computer get hacked using it? I use Wavebroadband via cable on my HP computer. I do not use the app on my phone.
Its perfectly safe to use. Its on your own local lan. the only way you’d get hacked is if you had someone else on your network that was nefarious. If you gave them your info or connected their device to your network, there’s much worse they’ll get than access to the g34
  • January 16, 2025
