BEST WAY TO UTILIZE CAT 5 BETWEEN FLOORS
  • April 2, 2025
  • 41 views
I have a G36 on one floor and have a CAT 5 that runs from that location to the second floor.  I am trying to figure out how to have one SSID network that covers house and right now the G36 isnt doing it.  I envisioned if I could have a wifi router hardwired to the G36 and then have another something on the second floor that is connected by the CAT 5 in the wall to either the G36 or the first floor wifi router?  Any help would be appreciated what i should buy or do.
For poor Wi-Fi coverage, several factors like interferences from microwaves, concrete walls, etc., can play a role.
The G36 can cover up to 2,500 sq ft, depending on these interferences.
If your space is larger, we recommend getting a mesh system. You can visit our website to explore various products and their features, and make a purchase accordingly.
Please refer to the links below to view our mesh products, their features, and to purchase one at your convenience.
https://www.surfboard.com/
https://shop.surfboard.com/
Note:
We recommend getting a dual pack if your space is larger.
If you're considering a mesh system, we suggest putting the G36 into bridge mode.
Bridge mode will disable the Wi-Fi features on the G36 and turn it into a cable modem. If it is a cable modem, only one of the Ethernet connections from the G36 will work, which should be connected to the mesh system. This will help prevent network interferences.
Note:
  • April 4, 2025
Who’s your ISP?
Reason I ask is the G36 has a decent modem in it. You could add a mesh system to it and either just use the G36 as an extra access point (not on same ssid) or disable its router features and just use it as a modem.
I’d take a look at Dong Knows website. He reviews a lot of networking/mesh systems and does a great job of it. He also pays for it himself to ensure he’s a neutral poster (for the most part) I’d post a link but they tend to get moderated. He’s got a few charts with mesh systems rated.
How big is the home?
What are the interior walls made of?
A hardwired backhaul between mesh systems usually makes them rock but not all support wired backhaul.
What speeds do you pay for?
