Bramd bew G34 not visible to ISP
  • July 16, 2023
  • 150 views
Just replaced a defective Netgear. Installed and contacted Cox who activated. Can see IP address, gateway, etc but Wi-Fi and LAN devices cannot connect to Internet. Wi-Fi (phone) shows as connected but no internet. Contacted Cox after activation and they now state they cannot see the device.
Hi Ridgely,
After activating the modem unable to connect to internet , check the followings to ensure for a better internet :
Check if the lights on G34  are Solid blue then try doing a Self Activation with your COX App .
If still unable to connect to internet try doing a  Reset and try again .
If the lights on G34 are Flashing Green then its searching for downstream and upstream channels of the cable signals .
In both LED light status try doing a Re-Provision(remove HFC MAC ID and add it back and activate it again ).
Also make sure  your ISP(Internet Service Provider) had removed your previous (netgear )HFC MAC ID .
Apart from the above, check with the below points also:
  • Ensure Co-axial cable is connected tight and power cable as well
  • Placing your gateway in the center of your home
  • Don’t put it behind any electronics or appliances
  • Don’t put it too close to cordless phones (landline not cell), baby monitors, or your microwave
  • Make sure it’s not behind a metal or concrete wall as the signal has a hard time going through them
Check with the below link for the Reset :
Let us know if this helps.
Hi Ridgely,
