Bridge mode on G36
  • May 13, 2024
  • 476 views
Is there a way of disabling the router portion of the G36 and using it strictly as a cable modem?  If so, what are the steps?
Yes in this case you need to follow the steps mentioned on the below article to enable Bridge mode on the modem.
http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Bridge-Mode-Setup
  • May 15, 2024
What if the Netgear Mesh Router is already using that IP?  Can I directly connect to the modem?
  • May 15, 2024
If you’re on a residential account for your Internet, you’re subscribed to one IP.  Only one device with the IP will have Internet access and other devices will not get an IP unless you subscribe to additional IP (if your ISP allows it).
