Compatability with ISP - G34
  • October 26, 2024
  • 22 views
Then ARRIS G34 gets denied and it's Engineering because ISP provider Sparklight and Cable One are not allowing the  ARRIS G34,  itself to compete with other Routers and Wifi models.  Maybe it's time for a change in brands. Correct.
The G34 is on sparklights compatable modem list and is recommended by them versus just compatible.
https://support.sparklight.com/hc/en-us/articles/115009158227-Supported-Modems-Residential-Only
Why is it getting denied? Or what error are you getting?
In this case you can check and reconfirm the modem compatibility with your internet service provider since we are unable to recheck on their official site.
  • 2287 replies
  • November 6, 2024
