compatible speed for G34
  • September 1, 2024
  • 23 views
I just bought an Arris G34 cable modem, but my internet plan is only up to 300 mps.  Can I still use this modem or is it not compatible with my internet speed/plan?
Best answer by Netopia
The G34 works with Internet speed plan up to 900 Mbps for most ISP.  You must check with your ISP to confirm if they allow G34 for your Internet plan.
Forum|alt.badge.img+30
  • Rockstar!
  • September 1, 2024
