Connect printer to G34
  • November 23, 2025
  • 27 views
I am blocked from 192.168.0.1 and can’t get wps set up online so that I can wirelessly connect my printer to my computer.  PLEASE give me wps access/account or something for wps so I can connect my printer.
Could you please confirm your product’s model number?
  • December 5, 2025
  • December 5, 2025
I got to the control panel with admin - what password do I type in?
I tried the wifi password and that didn’t work
  • December 5, 2025
What password do I type into the admin panel?
There is no default login password for this interface.
For ARRIS models G34 during the initial setup, you’ll be prompted to create a password for accessing the web interface.
If you’ve been using the web interface to configure your Surfboard gateway and happen to forget the password, we would recommend performing a factory reset on the device. This will restore the gateway to its default settings, allowing you to set a new password for the web interface.
