connecting printer to router
  • April 19, 2023
  • 1233 views
My HP OfficeJet, pro 8600 is having trouble connecting to my new arris router. The printer says to check if MAC address filtering is enabled I don’t remember setting that up all of my more modern devices have no trouble connecting to the router. Can I get some help in connecting the printer to my new router?
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
  • Cable Modem Commandos
  • April 20, 2023
http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Unable-to-Connect-to-the-Wi-Fi-Network try these steps and then retry the connection to your printer
http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Customize-Guest-Wi-Fi-Network if you do not want to make changes to your main network maybe you can try to create a guest for your printer by following these steps http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Customize-Secondary-Wi-Fi-Network or a secondary network that works separately from your main network but remember to disable the WPA3 as the first link shows it
