Connecting VoIP phone with G34
  • May 24, 2024
  • 110 views
I have a VoIP phone line that I need to connect to the Arris Surfboard G34 but there is no where to plug it into. How do I connect the VoIP to the Arris
G34 modem doesn't have phone port on it to connect the phone line so you can check on the phone whether any option available to connect phone to the modem using Wi-Fi.
