deactivate 6/802.11ax on surboard wifi cable modem ax3000
  • November 3, 2023
  • 37 views
How to deactivate
  1. 6/802.11ax on surfboard WiFi cable modem AX3000 WiFi 6
Why do you want to?
The wireless on it is pretty solid and it’d be better to properly setup the network or fix your issues versus hamstringing the device.
  • 2277 replies
  • November 4, 2023
Why do you want to?
