Device names
  • November 12, 2024
  • 26 views
How can I tell what the device is from the identification code on the connected device list?
The connected devices on the modem GUI or the setting page can be identified using the name or by the IP address of that devices. You can check the IP address of the device under settings then confirm the same on your modem GUI connected device list then you can edit the name of the devices.
