Answer
dropped and intermittent wifi and slow nowhere close to 800mps
  • July 18, 2025
  • 7 replies
  • 79 views
i contacted comcast.net over five times but still dropped and intermittent wifi and slow nowhere close to 800mps which i pay extra
Would it be possible for you to connect a computer directly to the gateway using an Ethernet cable? This would help us determine if the internet drops only on the Wi-Fi, or if it affects both Wi-Fi and hardwired connections.
Make sure that the gateway is placed in an open area to minimize Wi-Fi congestion.
If you find that the internet drops only on the Wi-Fi, I would suggest trying to change the Wi-Fi channels to improve the connection
It would be helpful to try changing the Wi-Fi channels to reduce congestion and improve the connection quality.
Please refer the link below, where you can find the steps to change the Wi-Fi channels
Could you please help us with your model number and speed plan which you are subscribed to?
  • July 20, 2025
G36 & 800MPS
  • July 27, 2025
the link to change wifi channels does not work
We apologize for the inconvenience. Please try the link below, where you’ll find step-by-step instructions on how to change the Wi-Fi channels for your ARRIS G36 modem:
 https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G34-G36-Changing-the-Wi-Fi-Channel
  • July 31, 2025
im using chrome and the web interface keeps spinning and does not load could my unit be defective?
  1. Make sure your phone, computer, or tablet is connected to the main Wi-Fi network of the gateway before trying to open the web interface.
  2. Unplug both the coaxial cable and the power cable from the gateway. Then, plug in only the power cable (leave the coaxial cable unplugged).
  3. Note: Without the coaxial cable, the LED will flash blue, the Wi-Fi network names will still show up, and you can connect your device to them.
  4. If you can, connect a computer directly to the gateway using an Ethernet cable. This gives a more stable connection, but it's okay if you use Wi-Fi instead.
  5. Once you're able to log in to the web interface, plug the coaxial cable back in.
  6. Wait until the LED turns solid blue, which means the internet is working.
  7. Refresh the web interface page to check if you're still logged in and connected to the internet.
