G34-2731 Won't connect to HP6525 printer
  • November 26, 2025
  • 39 views
Printer test results say MAC address filtering is preventing it from connecting.  How do I change this?
Usually, it’s not necessary to add the MAC address. Please follow the steps below.
Most printers connect using the 2.4 GHz network, and they typically work best when the 2.4 GHz encryption method is set to medium.
Please refer to the link below for instructions on how to change the encryption method for the 2.4 GHz network:
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G34-G36-Unable-to-Connect-to-the-Wi-Fi-Network
Once the encryption method has been updated, check whether the printer is able to connect to the 2.4 GHz network.
  • November 29, 2025
Did you contact the printer manufacturer?
Thats usually the first step.
Most routers don’t care what connects to it.
