G34 and an Arris vap2500 access point
  • April 13, 2025
  • 129 views
Hello all, In November I purchased a new home along with an Arris G34 Modem Router Combo. Setup and activation went fine. I noticed my garage and the opposite end of the house had weak WiFi. I purchased an Arris VAP2500 access point to place there. I ran a network cable to the garage and hooked up the access point. In connected devices in my G34 the access point is listed and says online. My problem is I can’t login to the access point. Even before hooking it up I couldn’t get in. A WiFi search on a laptop and iPhone in the garage list the VAP2500 as a choice but I can’t join. all user names and passwords that came with it and searched online don’t work. My home system password doesn’t work either. Should I trash the VAP2500 and go with something else.
Thanks
VAP2500 is not supported by ARRIS.
ARRIS supports only the retail products that are available on surfboard.com but not the ISP lease products.
  • April 13, 2025
I just looked it up on amazon and the description says you also need a wireless receiver. Have you gotten one of those by now? I know this is an old post, I didn’t see any replies. But I would try getting one of those or just wifi extenders. You can just get 1 or packs of 2 or more. I have not had to get those but it might help solve your problem. I know somethings about tech and wifi like this but I am not an expert yet. If you end up getting those, then reset your 2 in 1 modem router so everything can receive the connection. If you still cannot get into your modem/router combo, call your internet provider or the arris company if you have not tried the app yet first.
  • April 14, 2025
The G34 isn’t a controller for that AP. I’d return it if its new and get an actual access point
