g34 and magic jack voip
  • April 15, 2023
  • 245 views
I have a magic jack voip device connected to an ethernet port on the G34.  Incoming calls often go straight to voicemail.  Most calls (incoming or outgoing) will drop if they last more than a few minutes.
The Magicjack device works fine on the gateway provided by my ISP, but I prefer to use the G34, if possible.  The Magicjack also works fine on my sons network (an Arris modem with netgear router).
I tried disabling SIP and forwarding ports 5060,5070, but the problem remained.
Perhaps unrelated, but I also get dhcp ipv6 error messages in the event log every 2 minutes.
Any suggestions?
Hello RickM,
The G34 might be experiencing intermittent issue if your other devices are loosing connection at the same time the magic jack voip experience drop connection.  If this is the case, I recommend checking the cable signal levels in the G34. http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Cable-Signal-Levels
Please share the screenshot of the cable signal levels so we can check if they are on acceptable range .
Also, try using  different ethernet cables and check if you are able to see flashing lights on the ethernet ports (please do try with all the ethernet ports)
In addition, make sure UDP protocol is selected in your port forwarding rule for ports 5060 and 5070.  If the issue doesn’t go away, remove the port forwarding rules and setup DMZ to forward all ports for testing purpose. https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/G34-G36-DMZ-Setup
  • April 29, 2023
Sorry for taking so long to reply.  I was away from home for awhile, then had some issues getting the G34 activated by my ISP.
Anyway, first, I had previously tried the Port forwarding and DMZ, but I did a factory reset then tried again and the problem with VOIP still exists,
I looked at the QAM tables and the download table looks good.  The upload seems a bit off.  (See below)
Any further thoughts or suggestions?
Downstream QAM
Index
Frequency (MHz)
Power Level (dBmV)
SNR (dB)
Modulation
Lock Status
1
561
3.799999
38.983261
QAM256
Locked
2
567
3.599998
38.983261
QAM256
Locked
3
573
4.099998
38.605377
QAM256
Locked
4
579
4.300003
38.983261
QAM256
Locked
5
585
4.900002
38.983261
QAM256
Locked
6
591
4.699997
38.605377
QAM256
Locked
7
597
4.300003
38.983261
QAM256
Locked
8
603
3.700001
38.605377
QAM256
Locked
9
609
3.799999
38.605377
QAM256
Locked
10
615
4.300003
38.605377
QAM256
Locked
·  1
·  2
·  3
·  4
Upstream QAM
Index
Frequency (MHz)
Power Level (dBmV)
Channel Type
Symbol Rate (KSym/sec)
Modulation
Lock Status
4
37.4
41.270599
US_TYPE_ATDMA
5120 KSym/sec
64QAM
Locked
3
31
39.270599
US_TYPE_ATDMA
5120 KSym/sec
64QAM
Locked
2
24.6
38.770599
US_TYPE_ATDMA
5120 KSym/sec
64QAM
Locked
1
18
38.260300
US_TYPE_ATDMA
2560 KSym/sec
64QAM
Locked
I'm also including a copy of a few lines from the Event log.  They may not be relevant, but they messages occur approximately every 2 minutes.
ti_dhcp6c: 72001009-DHCPv6 - No Advertise or Reply Received 5 times
04/28/2023 16:24:51
Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 14 Retries Attempted with Last attempt at Fri Apr 28 20:23:02 2023
04/28/2023 16:24:51
Critical
ti_dhcp6c: 72001009-DHCPv6 - No Advertise or Reply Received 4 times
04/28/2023 16:23:02
Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 13 Retries Attempted with Last attempt at Fri Apr 28 20:21:02 2023
04/28/2023 16:23:02
Critical
ti_dhcp6c: 72001009-DHCPv6 - No Advertise or Reply Received 3 times
04/28/2023 16:21:02
Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 12 Retries Attempted with Last attempt at Fri Apr 28 20:18:55 2023
04/28/2023 16:21:02
Critical
ti_dhcp6c: 72001009-DHCPv6 - No Advertise or Reply Received 2 times
04/28/2023 16:18:55
Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 11 Retries Attempted with Last attempt at Fri Apr 28 20:16:45 2023
04/28/2023 16:18:55
Critical
ti_dhcp6c: 72001009-DHCPv6 - No Advertise or Reply Received 1 times
04/28/2023 16:16:45
Critical
