G34 device list has false positives and negatives
  • October 15, 2025
  • 8 replies
  • 95 views
My G34 GUI device list shows many devices which Windows 10 nmap shows are currently down, and at least one currently nmap up device doesn’t show.  How does the G34 assemble its device list?  Can I improve it?
There isn’t a specific time frame available for background synchronization on the G34, as this process occurs automatically in the background.
We recommend setting a strong and secure password for your network ideally one that includes a combination of letters, numbers, and special characters to enhance security.
If you're referring to the connected devices list in the interface, then yes it displays the devices currently connected. However, please note that you cannot add, remove, or reorder devices, as those options are not available.
  • October 16, 2025
The reply around noon PST 10/16/25 from SURFboard Moderator says nothing about either down devices (stale) still appearing or up devices (online) not appearing.  Those are what I asking about.  It’s not a list of connected devices, it’s a list of devices some of which are not connected and with some connected devices not in the list.
If you're referring to the connected devices list not updating, we recommend trying the following while logged into the interface: go to Troubleshooting > Restart/Restore, then click on Restart Gateway. This will refresh the entire gateway, and afterward, check if the device list has been updated.
  • October 19, 2025
Thanks, that gets me halfway.  The new devices list doesn’t show down devices any more.  But nmap shows 4 up devices not in the G34 list.  Can you tell me exactly what the G34 does to build this list?  I would guess it’s not ping nor nmap since the list doesn’t equal either one.  And perhaps easier, is there a way to make it try again and see if it picks up the up devices it missed upon Restart?
  • October 19, 2025
Guess I see the answer.  Just wait and possibly re-log in and more devices show up.  Still hope you can tell me  exactly what the G34 does to build this list.
The Connected Devices list displays devices that are currently online. Please note that when a new device connects to the Wi-Fi, it may not appear immediately in the list. The system performs a background synchronization, and the device will show up once that process is complete.
  • October 23, 2025
Good, that narrows it down.  But I still would like to know (1) when and/or how often does the background
synchronization occur and how can I tell when the last or next one is, and (2) your statement that the list displays devices that are currently online isn’t complete because devices stay on the list, as far as I know for a very long time, even when they’re no longer online, so does the G34 ever remove them from the list, how often, and how can I find out the last and the next time it will do so?  My goal is detect unwanted devices e.g. hackers.  Obviously the quicker I catch them the better chance I have of preventing harm, and learning there was a hacker days ago raises useless alarm for me.
