Answer
G34 ethernet port not working need help
  • January 29, 2025
  • 92 views
My G34 the wireless connection works perfectly but my ethernet ports don't work at all.
I've tried getting new cables, restarting the router, resetting it . Nothing helped
Could you please let us know if there were any lights on the Ethernet port when the ports were connected?
Please try accessing the web interface by using http://192.168.0.1 on the any device connected via Wi-Fi.
After logging in, go to Gateway > Hardware > Ethernet. There, you’ll find an option to toggle the port by disabling it and then enabling it again.
Then, I would suggest you to check if the ethernet connection works.
If still persists then I would recommend performing a factory reset on the device. This will restore the gateway to its default settings.
  • February 3, 2025
Hi ,
Thanks for the response
Connected with the customer support team and tried these options with no luck.
A replacement request has been placed.
