So when I setup my g34 my isp said any issues would be with the modem/router company, anyways my issue had been fluctuating download speeds which should be a 940mbps and upload up to 100 but I'm getting a max of 5 and as low as 100 kilobytes
g34 - Intermittent internet connection
Since you are experiencing slow/ intermittent internet connection with both wired and wireless connection, I suggest you to check the cable signal levels and also change the Wi-Fi channels and monitor the same for the next 24hours of time.
To change the cable signals, follow the instructions given below:
To change the Wi-Fi channels, find the instructions given below:
