G34 lan disconnects and reconnects at 8:11 every night
  • August 24, 2023
  • 48 views
Every night at 8:11 pm cst my modem disconnects wired connected devices. Why does it do that?
Hello todmerrifield82
                                       If the modem is dropping internet connection on particular time we would suggest you to check on device connected to the modem LAN port and If the modem has issue it would drop randomly and reboot automatically but since in this case there might be a issue with ISP as well so you can contact internet service provider to check on this.
