G34 not broadcasting ssid and ethernet ports not working
  • July 22, 2025
  • 28 views
So, I have a Arris G34 that is approximately a year old and its not broadcasting ssid and ethernet ports not working. Everything was working great till I moved to a new house. I have Cox internet and I am receiving good signal. I can plug cox panoramic in and the internet works just fine.
When I reboot or factory reset the G34 the ethernet ports light up while it reboots but then turn off and do not come back on no matter what I have plugged In to them. I cant seem to figure out how to login to the modems web page to check out the setting due to lack of internet.... Any advice/help before I try and do a warrenty claim will be greatly appreciated!
Could you please share the details of your subscribed internet speed plan, as well as the current LED light status on your modem? This information will help us understand why the Wi-Fi network names are not broadcasting.
  1. Click on the Apple menu.
