g34 not enabling guest network
  • September 13, 2025
  • 33 views
Guest network disappeared after restart of g34
If you’ve performed a factory reset, you may need to re-enable the guest network manually.
However, if you’ve only restarted the gateway, this step may not be necessary.
We recommend restarting the Wi-Fi module through the interface by navigating to: Troubleshooting > Restart/Restore > Restart Wi-Fi & Router.
Please make sure that the coaxial cable is disconnected during this process for best results
