G34 - Running Logs & Intermittent Connection
  • March 18, 2023
  • 538 views
Hello.  New to this.  I have Xfinity Internet 800 mbps. I bought a G34 Xfinity approved Modem/Router.  I am on my second modem/router where I am getting intermittent connectivity issues where the connection just falls of to 1-2mbps or nothing at all many times a day.  I have had Xfinity out inspecting signals, taps, etc. and “everything is fine”.
Wondering the following
  1. What next steps can I take to troubleshoot and mitigate this?
  2. Is there a way I can run connection logs that I might interpret or provide Xfinity for troubleshooting?
Really appreciate any assistance on this mind bending problem.
Thanks!
  • March 18, 2023
Not sure if these are the correct logs but here we go:
DHCPv4: 72001001-DHCPv4 Provision - Completed
    03/18/2023 09:55:17    Informational
ti_dhcp6c: 72001002-DHCPv6 Provision - Completed
    03/18/2023 09:55:08    Informational
ti_dhcp6c: 72001011-DHCPv6 - Missing Required Option 24
    03/18/2023 09:55:04    Critical
ti_dhcp6c: 72001011-DHCPv6 - Missing Required Option 82
    03/18/2023 09:55:03    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Sat Mar 18 09:55:02 2023
ti_dhcp6c: 72001015-DHCPv6 Failed - No Prefix Available
    03/18/2023 09:55:02    Critical
ti_dhcp6c: 72001014-DHCPv6 Failed - No Address Available
eRouterEvents: 72003004-eRouter enabled as Dual Stack
    03/18/2023 09:54:59    Informational
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 09:54:49    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 09:54:42    Warning
CM-STATUS message sent.  Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 09:52:14    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 09:52:12    Critical
DS profile config update.  DS Chan ID: 193.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 09:32:11    Notice
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 08:52:28    Critical
CM-STATUS message sent.  Event Type Code: 5; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/18/2023 08:38:25    Notice
eRouterEvents: 72003001-eRouter is administratively disabled
    03/17/2023 19:33:42    Informational
DHCPv4: 72001020-DHCPv4 - IP Address Released
    03/17/2023 19:16:52    Informational
    03/17/2023 19:13:55    Informational
    03/17/2023 12:35:49    Informational
    03/17/2023 12:35:34    Informational
    03/17/2023 12:35:29    Critical
    03/17/2023 12:35:28    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Fri Mar 17 12:35:28 2023
ti_dhcp6c: 72001004-DHCPv6 Provision - 1 Retries Attempted with Last attempt at Fri Mar 17 12:35:27 2023
    03/17/2023 12:35:25    Informational
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:35:10    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:35:05    Warning
Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:34:27    Error
    03/17/2023 12:33:40    Informational
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:33:30    Critical
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:32:47    Warning
CM-STATUS message sent.  Event Type Code: 2; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:32:44    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:32:42    Critical
CM-STATUS message sent.  Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:31:20    Notice
    03/17/2023 12:31:12    Informational
    03/17/2023 12:30:59    Informational
    03/17/2023 12:30:55    Critical
    03/17/2023 12:30:54    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Fri Mar 17 12:30:53 2023
    03/17/2023 12:30:53    Critical
    03/17/2023 12:30:51    Informational
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:30:32    Warning
Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:29:52    Error
    03/17/2023 12:29:03    Informational
    03/17/2023 12:29:00    Informational
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:28:40    Critical
    03/17/2023 12:28:01    Informational
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:28:00    Warning
    03/17/2023 12:27:57    Critical
    03/17/2023 12:27:56    Critical
CM-STATUS message sent.  Event Type Code: 2; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:27:55    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:27:55    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Fri Mar 17 12:27:54 2023
    03/17/2023 12:27:54    Critical
CM-STATUS message sent.  Event Type Code: 2; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:27:54    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:27:54    Critical
    03/17/2023 12:27:52    Informational
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:27:33    Warning
Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:26:54    Error
    03/17/2023 12:23:51    Informational
    03/17/2023 12:23:50    Informational
    03/17/2023 12:23:47    Informational
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:23:37    Critical
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:22:47    Warning
CM-STATUS message sent.  Event Type Code: 17; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:22:44    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:22:43    Critical
    03/17/2023 12:21:50    Informational
    03/17/2023 12:21:38    Informational
    03/17/2023 12:21:33    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Fri Mar 17 12:21:31 2023
    03/17/2023 12:21:32    Critical
    03/17/2023 12:21:31    Critical
    03/17/2023 12:21:29    Informational
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:21:12    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:21:07    Warning
Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:20:27    Error
REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:47    Critical
T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:47    Error
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:46    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:35    Warning
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:31    Warning
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:25    Critical
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:04    Warning
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:16:00    Critical
Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:15:38    Error
    03/17/2023 12:13:52    Informational
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:13:34    Critical
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:12:52    Warning
CM-STATUS message sent.  Event Type Code: 21; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:12:50    Notice
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/17/2023 12:12:47    Critical
    03/17/2023 10:08:29    Critical
    03/17/2023 10:08:28    Critical
    03/15/2023 13:38:34    Informational
root: 72002001 -  LAN Provisioning No Prefix available for eRouter interface 11
    03/15/2023 13:38:30    Critical
root: 72002001 -  LAN Provisioning No Prefix available for eRouter interface 12
    03/15/2023 13:38:24    Informational
    03/15/2023 13:38:20    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 1 Retries Attempted with Last attempt at Wed Mar 15 13:38:19 2023
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Wed Mar 15 13:38:20 2023
    03/15/2023 13:38:17    Informational
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/15/2023 13:38:05    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/15/2023 13:37:58    Warning
    03/15/2023 13:28:08    Informational
    03/15/2023 13:27:47    Informational
    03/15/2023 13:27:42    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Wed Mar 15 13:27:41 2023
    03/15/2023 13:27:41    Critical
    03/15/2023 13:27:38    Informational
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/15/2023 13:27:30    Critical
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/15/2023 13:27:23    Warning
DS profile config update.  DS Chan ID: 193.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;    03/15/2023 12:14:26    Notice
    03/15/2023 10:08:31    Critical
    03/15/2023 10:08:30    Critical
[Wifi]:  KeyPassphrase changed
    03/14/2023 20:29:59    Notice
    03/14/2023 20:29:39    Notice
    03/14/2023 19:55:29    Informational
    03/14/2023 19:55:23    Critical
    03/14/2023 19:55:18    Informational
    03/14/2023 19:55:15    Critical
    03/14/2023 19:55:14    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Tue Mar 14 19:55:13 2023
    03/14/2023 19:55:13    Critical
    03/14/2023 19:55:10    Informational
    03/14/2023 15:31:47    Informational
    03/14/2023 15:31:39    Informational
    03/14/2023 15:31:35    Critical
    03/14/2023 15:31:34    Critical
    03/14/2023 15:06:00    Informational
    03/14/2023 08:31:34    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Tue Mar 14 08:31:33 2023
ti_dhcp6c: 72001004-DHCPv6 Provision - 1 Retries Attempted with Last attempt at Tue Mar 14 08:31:32 2023
    03/14/2023 08:31:33    Critical
    03/14/2023 08:31:31    Informational
    03/14/2023 08:25:22    Informational
    03/14/2023 08:25:18    Informational
    03/14/2023 08:23:01    Informational
    03/14/2023 08:22:51    Informational
    03/14/2023 08:22:46    Critical
    03/14/2023 08:22:45    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 1 Retries Attempted with Last attempt at Tue Mar 14 08:22:44 2023
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Tue Mar 14 08:22:45 2023
    03/14/2023 08:22:43    Informational
    03/14/2023 08:05:57    Informational
    03/13/2023 19:29:37    Informational
    03/13/2023 19:29:29    Informational
    03/13/2023 19:29:25    Critical
    03/13/2023 19:29:24    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Mon Mar 13 19:29:23 2023
    03/13/2023 19:29:23    Critical
    03/13/2023 19:29:21    Informational
    03/13/2023 16:58:17    Informational
    03/13/2023 16:58:13    Critical
    03/13/2023 16:58:09    Informational
    03/13/2023 16:58:05    Critical
ti_dhcp6c: 72001004-DHCPv6 Provision - 0 Retries Attempted with Last attempt at Mon Mar 13 16:58:04 2023
ti_dhcp6c: 72001004-DHCPv6 Provision - 1 Retries Attempted with Last attempt at Mon Mar 13 16:58:03 2023
    03/13/2023 16:58:04    Critical
    03/13/2023 16:58:02    Informational
