G34 Wifi Issues as well as SURFboard App connection
I am trying to connect to my WiFi but unable to connect to both 2.4 and 5.
When trying to sign in on the app, it tells me to connect to the networks but am unable to. My ethernet works fine, but can not figure out what to do.
G34 w/ XFinity service
Could you factory reset the modem and connect the device with default Wi-Fi credentials which is at the bottom of the modem.
  • February 6, 2024
The WiFi has also been setup before but when logging onto the app it tells me to activate my setup again
