G34 will not connect to wifi
  • September 30, 2024
  • 84 views
WHY won’t my G34 connect to wifi
Best answer by Netopia
If you’re unable to connect to the G34 Wi-Fi network, you might need to change the Wi-Fi security type in the configuration page.  You’ll need to connect a device to the G36 with Ethernet cable if you don’t have any Wi-Fi device connected to the G34.
Here’s a link to help change the Wi-Fi security type setting.
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/G34-G36-Unable-to-Connect-to-the-Wi-Fi-Network
Forum|alt.badge.img+30
  • Rockstar!
  • 273 replies
  • October 1, 2024
