G34 will not hard reset
  • September 28, 2023
  • 455 views
Forum|alt.badge.img+3
I have a situation where I have had daily connection issues and had to do multiple hard resets. Now the unit will not reset. The way I know is because in the past when I do a 20 second reset the ethernet lights would turn orange. Now they won’t turn orange and will never connect.
BTW,  I have an open support ticket on this. I think I have a bad unit and I’m trying to get a replacement but I have to do the support dance. I explained that if the connection light never turns blue, they will never be able to diagnose the issue remotely. Am I correct?
Best answer by AUser
Got another rep who determined I needed a replacement.
Hello AUser
                    When you perform hard reset on the modem do you feel a click on the modem reset button?
                     If you are not feeling a click on the modem reset button please try using different thing to reset modem a sharp little thing.
                     please, disconnect the coaxial cable from the back of the device? At the back of the modem, in the middle section you will see a small hole, inside that hole there is a button, and that is the reset button, please insert a paper clip or a tip of a pen and hold it for 15-30 seconds until all your lights go off, afterwards connect the coax cable back and wait until your device fully boots up.
  • Button Mashers
  • October 1, 2023
Yes. I’ve had to do this numerous times in the last two weeks after continuing disconnection problems. I told two reps that it will not reset and it’s still under warranty. I have an older 300M router in its place right now because I have to have a connection.
All I need is a replacement.
The rep wanted to reset so they could do diagnostics. I explained that they won’t be able to do diagnostics if I don’t get a blue light.
If you looking for the warranty replacement, Please visit arris.com/selfhelp for more information.
Warranty inquiries are handled by Consumer Support.
  • Button Mashers
  • October 2, 2023
