G36 5gig slower than 2.4
  • September 29, 2022
  • 73 views
I just setup my G36 and was experiencing slow 5ghz connections on my phone. I did a speed test and it was barely registering. The 2.4 was smoking fast. I power cycled with same results. Any ideas why tne slow/dropping 5ghz?
Best answer by Ac313
Update. After doing more digging in the forum, I saw a postbabout changing the channel setting off of auto and manually selecting a channel. It worked, so far.
  • 2292 replies
glad to hear changing the channel helped!
What speeds are you getting now over 5ghz?
446 down. 37 up on my iphone 13.
  • 2292 replies
  • September 30, 2022
seems pretty reasonable.
