g36 and Xfinity connection drops daily
  • May 17, 2023
  • 28 replies
  • 2773 views
Show first post
Forum|alt.badge.img+2
  • November 20, 2023
If anyone finds a cable modem/router with a 2.5GB port that actually works with a 2.5GB switch, let me know. thanks……….
I use the XB8 from Infinity with the QNAP switch (QSW-2104-2S).  Works great with
the XB8 but absolutely would not work with the G36. And Arris support was non-existent
  • November 21, 2023
I’m having all the same issues. I’ve had this modem for 2 months and constant dropping connection on Xfinity which is too bad because the speeds, when it worked, were fast. I got it from Amazon, where it says it’s compatible with Xfinity, but I’m finding out now that it definitely isn’t. It’s outside the return window. Surfboard, can I please initiate a return for this. I’d love to see how good your customer service really is. I’d be happy to switch to one of your models that works well with Xfinity in exchange.
  • January 30, 2024
Any updates on the G36 issues yet? Firmware or issue with the 2.5gb port?
