G36 and Xfinity Event Logs - DHCPv6 - Missing Required Option 24 [Critical]
  • May 24, 2023
  • 561 views
Ebojager
The Certified
Forum|alt.badge.img+2
So, I might have solved some of my incompatibility with the Xfinity network by turning off the SIP option in the Advanced > ALG Settings, but I still get the once a day or so disconnect but only drops for a short time then recovers. I noticed a lot of these entries in the Event Log that may or may not be associated with the drops:
DHCPv6 - Missing Required Option 24 05/23/2023 04:25:43 PM Critical
DHCPv6 - Missing Required Option 82 05/23/2023 04:09:19 PM Critical
I’m curious how critical those are and if changing my iPv6 settings could help?
I noticed a checkbox for “Enable Stateful (DHCP Server)” which is checked. Im curious if maybe I should run with it unchecked but not sure what that would do???
I would appreciate any comments on the subject, thank you!
Surfboard Sux
The Many
Same problem. Same error. Just when you think the issue is solved, more problems!!!  You literally have to write down all systems edits. Only turn off 1 mode. Run it for days. Pull all reports; windows netsh wlan, surfboard event logs, system logs, print them to pdf, then compair reports daily to edits youve made.
And still doesnt work properly. Constant connectivity issues.
Surfboard Sux
The Many
Missing psk error is another persistant issue
