I bought a new G36. My TV is connected to it using a CAT5 Ethernet cable. I can not cast to the television from other devices on WiFi. I can't cast from a device on WiFi to a device connected via ethernet. Phone, tablet, desktop, none of them find my TV to cast to if it is connected using erhernet. If I unplug the eithernet cable, connect my TV to WiFi, I can then find the TV and connect. This wasn't an issue with my previous Arris surfboard. I can not find a setting that helps. UPnP is enabled. I also tried changing the firewall setting from medium to low. That did not work either. How can I fix this?  It's not just my TV either. My cable/TiVo device also has Android TV, it is also connected via Ethernet, and it is not available to connect to either.Â
