Upgraded from a Linksys+modem to G36 about 3 months ago. Had 99.999% uptime with my previous setup.
WiFi refuses device connection
WiFi not present (can’t see network). Sometimes 2.4G or 5G or both
Not internet (Wifi channels present, lan connected to computer)
2.5Gb lan loses connection
2.5Gb intermittent connection with switch (this may be a limitation of the G36 not designed to support this or not compatible with green specs)
All issues are resolved with hard power reset.
All of my equipment is not an issue (cat6 cable, multiple working switches, booming cable signal levels). Temperature controlled open area. I added an external fan and shroud to increase air flow though the G36 and this seems to reduce errors.
3+ hard resets per week is not acceptable.
Do I have a faulty product or is this normal for the G36?
