G36 intermittent
  • January 29, 2023
  • 146 views
New G36, Xfinity is provider. System FREQUENTLY is "available, no internet". Xfinity feed seems robust.
My laptop is attached via ethernet cable. From command line I can ping & get all packets sent & received. From Surfboard web site, ping shows all packets dropped. Help!
Best answer by Priya
The cable signal levels are completely out of range, which is why you’re facing this issue. Hence, please contact your service provider to reprovision the device.
Forum|alt.badge.img+4
  • Button Mashers
  • January 29, 2023
Hi nsh000
Could you please share the screenshot of "Connection / WAN" page (which has the upstream and downstream information) so that we can check if the cable signal levels are within the acceptable range.
  • January 29, 2023
  • January 29, 2023
 [edit: removed images with personal information]
  • Button Mashers
  • January 29, 2023
  • January 29, 2023
Thank you!
