I purchased the combo through Amazon. As soon as the window closed to return (1 month), it started dropping connections. After 6 service provider visits and nothing was resolved because the modem router would work and as soon as the tech would leave, it started dropping connections. Sparklight cannot update firmware and Arris won't. This is the only item that I have purchased from Amazon that is absolute junk and not cheap. NO ONE will address this issue.
Answer
G36 - Intermittent internet connection
Since you are experiencing intermittent internet connections on both wired and wireless connections, I suggest you to check the cable signals to make sure all signals are within range.
