g36 keeps dropping on Xfinity how do i warranty product?
  • November 16, 2025
  • 33 views
My Internet was working fine but it was time to upgrade old Xfinity equipment. I purchased the G36 and it drops wifi off an on all day. Unfortunately it's been more than 30 days so I cannot return to Amazon. Xfinity says the g36 has major issues with their system and don't recommend it. How can I warranty this product that doesn't work? Will a new g36 work or do I need a different model?? I've spent hours on the phone/chat line and am very frustrated. Where do I go from here?
We apologize for the inconvenience. To help isolate the issue, could you confirm whether the connection drops only over Wi-Fi or if it also occurs on a wired connection?
If it happens on both then we recommend checking the cable signal levels within the gateway. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G34-G36-Cable-Signal-Levels
  • November 20, 2025
The signals are in range, Xfinity tech came to the house and verified all connections are good. What do I do next? We're losing wifi, I don't have anything hardwired to the modem/ router
In this case, we recommend changing the Wi-Fi channels. Adjusting the Wi-Fi channel can help improve your network performance by reducing interference from nearby networks and devices.
Please refer to the link below for detailed instructions on how to change Wi-Fi channels
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G34-G36-Changing-the-Wi-Fi-Channel
