Out of nowhere, I got kicked off all my devices and my wifi just disappeared. Though, okay, maybe I should just reset it, but when I try to do 30-30-30 factory, nothing happens. Any ideas?
Answer
G36 Modem showing no wifi, won't reset & stuck with solid blue light
Could you let us know if there were any changes to the LED light status while the factory resetting the modem?
If there are no changes to the LED light, I request to disconnect all the cables from the modem, including the power cord. Wait a minute and reconnect it again.
Also, I suggest checking the IPV4 address on the computer or laptop that is connected to the modem.
