g36 router only wifi no ethernet connection
  • December 18, 2024
  • 90 views
This router was working fine but now only gives WiFi connection and not Ethernet even when computer is hard wired
thoughts to resolve?
thanks all
Try rebooting?
Try a different cable?
Try a different device?
Try a factory reset?
  • 2298 replies
  • December 18, 2024
Try rebooting?
  • December 19, 2024
I tried the top three answers no luck but a factory reset worked
many thanks
  • 2298 replies
  • December 20, 2024
Glad you got it working!
