G36 Secondary and Guest WiFi- Access through WebGui
  • October 2, 2023
  • 168 views
Both the secondary and Guest Wifi have different subnets- 192.168.26.1-x and 192.168.28.1-x. The Login page is accessible through the above (192.168.26.1 and 192.168.28.1).
My main gateway goes to a different router for dhcp etc., and I want to have similar settings for the two above.
However, the login/ password that I’ve set for the main page does not work for these. I’ve already tried the admin/cusadmin + password too without luck.
To log on to the GUI page of the Router which is 192.168.0.1, please login with the user name: admin and password: password (lower case).
If you face any issues in logging in to the GUI page kindly do a reset on the modem
Please follow the below link below :
Also, note when you do a Reset the Wi-Fi Name and Password will go back to the default Wi-Fi Name and Password if it is customized earlier.
