Help - modem reset itself
  • January 2, 2026
  • 29 views
My ARRIS (G34) - Cable Modem Router Combo - Fast DOCSIS 3.1 Gigabit WiFi 6 (AX3000) reset itself back to it’s factor settings. I can’t login to change this. I tried to get the password reset to email what to do, but nothing is showing up. Ideas?
Could you please clarify what you are unable to log in to? Are you referring to the Wi-Fi connection or the G34 web interface page?
If you are referring to the web interface, please specify what prompt or message it is displaying
