Hookup G 36 to HP 8620 PRINTER
  • February 1, 2023
  • 167 views
Can’t get HP 8620 printer to hookup to Wi-Fi with a G 36 router modem
Best answer by ETE
Thank you for your responses.
Plemens you were correct the setting needed to be changed to WPA2-PSK.  However we could not locate on the Surfboard portal where this exactly needed to be changed.  After calling Customer Support 4x, we finally got a very nice gentleman to walk us through the steps.  I am going to outline them for any one else that needs to hook up a printer with an Arris Surfboard Router/modem.
PRINTER MUSTBE ON
Log into portal; it will bring you to Gateway>Summary page
select Connection>WI-FI >NETWORKS
Under Primary Home ;On the 2.4 GHz line, select the EDIT button,  this brings you to the screen you can change the security mode.
Select WPA2-PSK; input the CAPTCHA at the bottom and Hit SAVE.
Turn printer off for 30-35 seconds, turn back on and you should be all set.
  • February 1, 2023
what error do you get?
Did you contact HP on it?
They’d be the experts on setting up their printer.
  • February 1, 2023
If you’re using wpa3, try setting it for wpa2. Some devices have issues with wpa3 (from my experience)
  • February 2, 2023
PRINTER MUSTBE ON
