I cannot find a way to connect my printer it says that I have to add the MAC address to the router to accept it but I can not find where to do that, I see no where to add a device with in the surfboard hub.
How to connect printer in G34
Since you are trying to connect the printer with this model G34, I suggest you change the security mode in 2.4Ghz.
Let me help you with the steps.
Launch the web browser>enter it in the address box as 192.168.0.1>login.
Gateway>summary>connection>Wi-Fi>networks>edit.
Then select security mode as WPAWPA2-PSK(TKIP/AES).
After changing the security mode, power cycle the printer once and connect with 2.4ghz Wi-Fi network.
